Help with some new hardware
So I am planning to upgrading my rig, my current specs are
Gigabyte GA-PA65-UD3-B3
Intel core i5 2500K.
Noctua NH-d14 cpu cooler.
Gigabyte Radeon HD 7950 Windforce 3.
I cant remember the name of my RAM, but it's really old 1333Mhz ram.
Corsair HX-650W PSU
Now for the actual question, I am planning to upgrade to a Haswell CPU (i5 4670K) and I will also get my hands on some Vengeance pro RAM (To fit my CPU cooler)
I would like to know if I should buy a Asus Maximus VI Hero or a MSI z87a-G45 Gaming mobo.
I would also like to know if I should get the Corsair 16g (8x2) CL9 1600Mhz Vengeance pro RAM or if it would be worth getting the 16gb cl10 2400Mhz Vengeance pro ram.
Thank you for answearing, it's greatly appreciated!
dude there's no need to upgrade from a 2500k, infact a lot of 2500k's overclock way better than haswell. just get a Z77 motherboard and you're set. (also that should give you the opportunity to ramp the ram up to 1600 Mhz)
as for GPU, with all the cash I just saved you by telling you this you can buy a top of the range card, although I think the 7950 is plenty.
