Get a 500 watt PSU and a better case. The power draw for your system is only 400 watts
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/38944-help/#findComment-500990
Get a 990 mobo instead of a 970 because I have heard they are a lot more stable on *3** AMD CPU's such as the 8(3)50 and 6(3)00.
Also def get a better case, a shit case is never fun to build in, as far as the PSU, I would 600w
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/38944-help/#findComment-500999
need hard drives?
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/38944-help/#findComment-501007
ok you can go with this one for 800$
CPU-FX 6300
RAM-G.SKILL Ripjaws 8GB (2 x 4GB)
GPU-Saphirre Radeon HD 7970
Motherboard-ASUS M5A97
HDD-Western Digital WD Blue 1TB
Case-COOLER MASTER HAF 912
DVD Drive- Black SATA 24X DVD Burner
PSU-Corsair TX650
or this one for 700$
CPU-AMD FX 6300
RAM-G.SKILL 8GB (2 x 4GB) 1866
GPU-EVGA GTX 760
Case-Cooler Master Haf 912
PSU-CORSAIR Builder Series TX650
or this for 600$
CPU-Intel Core i3 3220
RAM-G.SKILL 8GB Ram(2X4GB)
GPU-EVGA GTX 760
Motherboard-MSI H61
HDD-Western Digital WD Blue 500GB
Case-NZXT Source 210
PSU-Corsair CX500
or this for the same price
CPU-AMD Phenom II X4
GPU-SAPPHIRE Radeon HD 7950
Motherboard-ASUS M5A97 LE R2.0 AM3+ AMD 970
Case-Rosewill Challenger
PSU-Corsair CX 500
or this for 500$
RAM-G.SKILL Ripjaws 4GB (1x 4GB)
GPU-SAPPHIRE Radeon HD 7850
Motherboard-ASUS H61M-A
PSU-Corsair CX430
you choose man
Manners Maketh Man
https://linustechtips.com/topic/38944-help/#findComment-501093
If you need hard drives then here's what I'd recommend: http://pcpartpicker.com/p/1k3uN
  • 2tb barracuda
  • 120gb Samsung 840
  • fractal design core 3000 usb 3
  • Asus m5a97 r2
  • sapphire 7870 ghz edition
  • AMD 6300
  • CoolerMaster Hyper 212 Evo
  • Corsair cx500m Semi Modular
  • Patriot IEM limited edition 8gb 1600 kit
  • Asus dvd drive
I don't know about you but for $770, a system doesn't get much better.
*edit: If you're about to ask. Yes! SSD's are bloody important!
https://linustechtips.com/topic/38944-help/#findComment-501098
Edits: http://pcpartpicker.com/p/1k4zo
Crossfire ready.
https://linustechtips.com/topic/38944-help/#findComment-501303
I don't need an HDD. I'm going to take the one I have now and use it in this new build. Honestly, I couldn't care less about how the case looks, I just need something that will get the job done.
As for the 990 mobo, I'll look at it and see. I really just wanted to know if that PSU would be compatible with my build, as I plan to run another 770 in SLI later on.
https://linustechtips.com/topic/38944-help/#findComment-503356
For 770 SLI, Corsair CX 750w (get modular one imho) will do its work.
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/38944-help/#findComment-503436
The psu will work. Why not get a 7970 which is nearly neck to neck with the 770 instead to save money and to get more vram?
https://linustechtips.com/topic/38944-help/#findComment-505693
