240 meter is a BIG fan..  ;)
I'd suggest plugging it into the CPU fan because it is the CPU fan.  the Whole system usually doesn't need to also speed up.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/388432-240m-fan-connection/#findComment-5243481
240m is a AIO by CM
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/388432-240m-fan-connection/#findComment-5243492
plug the pump into CPU_1 and use the Y for the fans and connect them to CPU_2
https://linustechtips.com/topic/388432-240m-fan-connection/#findComment-5243502
Okay so I connect the the wire coming from the CPU Block itself to CPU Header 1 and connect the Y Splitter wire to CPU Header 2. And I leave the fan controller.?
CPU: Intel Core i7-4790k. Motherboard: Asus Maximus VII Ranger GPU: MSI GTX 970
https://linustechtips.com/topic/388432-240m-fan-connection/#findComment-5243534
is it a fan controller or a fan hub on the noctis ? Cause the h440 has a fan hub which means 100% all the time. But yes plug the block into cpu 1 and the y splitter in the cpu 2 header and you should be good
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/388432-240m-fan-connection/#findComment-5246412
