Power Plug Question
Solved by Peter Vaughan Truslow,
So I have these speakers ok. And on the speaker is a pin for power. And on the pin says 6V DC. Now I didn't have the plug however I just found one right now that says AC to 6V DC Adapter.
On the back of the plug says Input: 100-240V~ 50/60Hz 0.5A and Output 6.0V ... 1.5A
So my question is is it okay for me to use this plug with the speakers. Thanks !!
if the speakers only need 1.5A or less at 6v DC, then that should work fine
