I was wondering if this reservoir: http://www.primochil...-system-copy-2/ Could be installed into the phantom 630 case or a phantom 820, I'm also not quite sure how one would install this reservoir as I couldn't find any guides on it.
Heres the PC part list if you're wondering: https://pcpartpicker...ed/#view=JTDNnQ
https://linustechtips.com/topic/387675-need-help-on-clearance-issues-for-cases/
Look at it NZXT website, they probably havethe amount of clearance written there.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
