Building for a friend
Solved by DarkBlade2117,
Plenty, it's when you go into 980tis or Titan X's in SLI or 290xs ect that a 850wwould come in handy, you'd have to buy a additional 6-pin connector for SLI as the PSU doesn't come with it. Those can easily be found on EVGAs website though.The psu was primarily because I saw it recommended in a thread the other day and for expansion potential.
check.
Say that he upgraded to a 4790k and wanted to sli 980s, would the 750 still be enough?
