Will I have enough power?
Go to solution Solved by j.dirona,
-snip-
Yes if you don't OC, but borderline, I would recommend going to 600 for safety sake. PSU's become less efficient over time so you may end up not providing enough power eventually.
So I want to buy a 780. My friend said he'd sale me his for 180$ My question is if my power supply will hold up?
Specs
  • CPU
    AMD Fx-8350
  • Motherboard
    Asus M59A7 R2.0
  • RAM
    Hyper X Fury - 2 x 4g
  • GPU
    Gtx 660TI
  • Case
    Cooler master haf
  • Storage
    Adata 240gig SSD / 3tb Kingston
  • PSU
    Corsair CX 500
  • Display(s)
    Benq Gw2750
  • Cooling
    Cooler Master Hyper 212 EVO
  • Keyboard
    Razer Blackwidow 2015
  • Mouse
    Razer Naga
  • Sound
    Hyper X Cloud Headset
  • Operating System
    Windows 7
https://linustechtips.com/topic/387199-will-i-have-enough-power/
On the Nvidia website (http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-780/specifications) it says you need a recommended minimum power supply of 600W.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/387199-will-i-have-enough-power/#findComment-5225135
Borderline adequate if no oc, highly recommend to upgrade it to a better quality 600w+ or higher if you planning to SLi the card.
https://linustechtips.com/topic/387199-will-i-have-enough-power/#findComment-5225181
They put it higher for shitty power supply as they can barely provide that much.
A decent 500w should be fine but you should OC so try to sell that PSU and get a 600w.
https://linustechtips.com/topic/387199-will-i-have-enough-power/#findComment-5225191
-snip-
Please use http://pcpartpicker.com/ for everybodones sake!
and quote me if you want me to see a reply please :)
pewpewpewphysicslazers!!!
https://linustechtips.com/topic/387199-will-i-have-enough-power/#findComment-5225736
