Anyone care to chime in on which is the best surface pro 3 model to get?
I can get the i5 with 128gb harddrive and 4gb of ram ~$1100
or I can get the i5 with 256gb of storage and 8 gb of ram. ~$1400
Is the extra money worth it?, Will I be hindered by the 4gb or ram?
CPU: i5 4670k GPU: GTX 770 Mobo: Z87-UD3H RAM: 8Gb Ripjaws Case: Corsair 200R PSU: Corsair RM750
https://linustechtips.com/topic/386803-which-surface-pro-3/
What are you planning on using it for? School, internet browsing, ect?
RIG: CPU: i5 6600k @4.8GHz 1.34v  CPU Cooler: H100i  Motherboard: Asus Z170-AR  RAM: Corsair Vengence LPX 2400 (2x8GB)
HDD: Seagate Baracuda 2TB  SSD: Samsung 850 Evo 500GB/PNY 240GB  GPU: Gigabyte G1 Gaming GTX 970  PSU: EVGA G2 650W
Please use PcPartPicker, and paste the "BB" code when posting your build!
https://linustechtips.com/topic/386803-which-surface-pro-3/#findComment-5220276
Honestly you'll probably never use the extra RAM, but the extra storage would definitely be nice. There's always the option of a 64/128GB MicroSD card for stuff that you won't mind lower access speeds to (such as multimedia).
"Rawr XD"
https://linustechtips.com/topic/386803-which-surface-pro-3/#findComment-5220295
I will be using this for school. I am going into engineering next year. I have a desktop for anything intensive, but I thought the extra ram could be be useful if I have to run any engineering software or if I'm multitasking.
https://linustechtips.com/topic/386803-which-surface-pro-3/#findComment-5220310
