Is my build overclocking safely?
Solved by Godlygamer23,
Is this something I need to worry about? I can't really find the operating range for the AMD 760G chipset
No, you should be fine. Just make sure you have proper airflow.
Serendipity1344 ·
Posted in Graphics Cards1 -
1
1
5
1
toxic_worper ·
11
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
