ok so i have 2 7870s in crossfire one is a reference cooler and the other is a direct cu 2. when the computer is using one gpu it uses the reference cooler and i would prefer it to use the direct cu2 one... bc better cooling man so like  how do i do this
not necessary to make multiple treads on the same subject matter: http://linustechtips.com/main/topic/386005-help-with-crossfire/
https://linustechtips.com/topic/386006-crossfire-help/#findComment-5210679
Guest
