Help with crossfire
Go to solution Solved by Fictionvl,
okay, here's what you have to do, since both cards are clocked at different speeds, try to get both cards at the same clock, and try it again.
Like remove one card, and clock the one in, then do the same for the other card
Okay so i had a reference 7870 and i wanted more preformed so i bought a second 7870 (asus direct cu 2) and i dont think the crossfire is working.  in catalyst controll it says my first gpu's activity is like actually doing shit and its at 1000mhz on gpu and 1200 mhz on the memory. my second graphics card is always  at 0% activity  and the gpu clock is always at  300 and the memory is always at 150mhz.  Ive also havent noticed a fps increase in my game, if there is one its like 5 fps please help!
https://linustechtips.com/topic/385969-help-with-crossfire/
Are you using a crossfire physical bridge?
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/385969-help-with-crossfire/#findComment-5210172
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/385969-help-with-crossfire/#findComment-5210203
Good :P The second GPU could be dead or has ESD damage, either way, it's not active.
https://linustechtips.com/topic/385969-help-with-crossfire/#findComment-5210205
i think they are but ill maunnually set them to the same speed
https://linustechtips.com/topic/385969-help-with-crossfire/#findComment-5210224
i just went in to the controller and manully set then both instead of taking them out bc i did that and itr worked!! ty
https://linustechtips.com/topic/385969-help-with-crossfire/#findComment-5210250
you're welcome :)
https://linustechtips.com/topic/385969-help-with-crossfire/#findComment-5210307
