Will these work together?
Go to solution Solved by PetiteBob,
All should work, Next time use PC part picker to put in the parts and it should come up if it is compatible or not.
Link is in Signature
Hey guys,
I will be building my first PC and have chosen the components. I checked to see if they were all compatible and I found that they were, but It would be great if you guys could double-check  the parts for me, because this is my first build. It would be a lot of help if you guys could give me insight on what kind of performance I would get from this PC, as it will primarily be a gaming PC. The last question for you guys I have is if Windows 8.1 PRO is necessary for me (vs just 8.1) and what version should I buy if I am installing it by creating media (flashdrive). For example: DVD bundle, OEM version, just the activation key?
Thanks
Parts:
CPU: http://ark.intel.com/products/65719/Intel-Core-i7-3770-Processor-8M-Cache-up-to-3_90-GHz
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813121605
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147372&cm_re=samsung_850_evo-_-20-147-372-_-Product
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339&cm_re=western_digital_hard_drive-_-22-236-339-_-Product
Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487132&cm_re=evga_geforce_gtx_960-_-14-487-132-_-Product
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817438016&cm_re=evga_500w-_-17-438-016-_-Product
I left out the case, Optical Drive, and Ram because I bought an ATX case already and Optical Drive and 8gb DDR3 Ram is purchased too.
Thanks guys!
https://linustechtips.com/topic/385720-will-these-work-together/
Yes. You need some RAM.
https://linustechtips.com/topic/385720-will-these-work-together/#findComment-5207313
