a month ago i installed a fresh copy of windows on a new ssd and i bought a 1tb wd green drive today to add storage. i installed it and turned my pc on and it wouldnt come up in my computer. i tried it twice without any success. i then decided to mess around with settings in the bios and i changed around the modes such as ide and ahci and i changed the legacy and uefi to uefi only annd legacy. after playing around with these settings my computer wouldnt even boot into windows anymore it would just put me in the repairing loop. i then booted into safe mode and refreshed windows and i literally just installed my lan driver. i finnaly got my computer to work but i am still faced with the problem of the hdd. i still need to install it. Please Help i know installing the hdd is a very easy task but it just wont work for me.
https://linustechtips.com/topic/385710-hdd-install-issues-please-help/
Go to your storage management. You need to initialize the HDD before you can format/use it.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
Try your hdd in another pc in the house
it might be dead
ill try that but i can hear it turn on. i was thinking it was more of a problem about which sata port its plugged into.
also can i plug in an internal drive while my pc is on or not
There's usually an pop-up message to initialize whatever drive is hooked up but the system needs to be restarted first. Did you reboot before you accessed storage management? If so and if a popup is saying it failed to initialized, the HDD maybe DOA.
Edit:typo
Edit:typo
there was no message and no fail popup. literally no acknowledgement of its existence
Does BIOS show it? If yes, its working ok. If no, its either DOA or cables aren't tight. After that you will need to format and sign letter to it. There are many free, paid and bootable tools for that. Like win install thing. It also should show up in disk management.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
