Hey guys,
I've just got payed from my summer job and I'm planning on building a new PC.
My budget is $5000 CAD, including a monitor and periferals
Only Intel core CPU's please.
I also am not interested in water cooling but include the max case fans please
Thanks
Also no OS
https://linustechtips.com/topic/385509-5k-build-help/
Hey guys,
Thanks
Also no OS
What will you use it for?
If it's for gaming, what kind of games?
If it's for productivity, what kind of things will you be doing?
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204790
5000 CAD = 4000 USD
and you only need about 1500 USD for a really good PC
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204791
http://pcpartpicker.com/p/tjDxK8
thats about 2500 CAD
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204804
Not an overkill case at all. :)
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204832
I used half his budget, if he wantewd to, he could add a second 980ti and a 4k monitor, with 32GB of RAM
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204840
With the case, not to mention one of the worst PSUs EVGA makes.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204847
its still a good PSU
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204854
Yeah but you don't skimp out on a PSU. So why not spend a little more to get a better, more efficient one.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204880
its 80+ gold, it doesnt need to be more efficient, if he SLIs, then get a 850W corsair
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204896
By efficient I mean the better version of that PSU a.k.a the G2/P2/B2 versions of these PSUs.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204911
why though? how are those better?
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204914
A good gaming PC doesn't need a $4000 budget. $1500 is enough for all of your gaming needs with anything above $2000 being wasteful. Unless you are doing some serious rendering, 3D modeling, and business work its just not needed. Better to put your money elsewhere.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204915
agreed, unless you want a 5960x and dual titan Xs just so tell your friends.
Solitaire.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204927
Because the B1/G1/P1 are bad PSUs, ask anyone that knows something which they would recommend. Also do you think if the first line was good they would make a second line of the same branding but better quality?
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204989
not overkill at all ;)
PCPartPicker part list: http://ca.pcpartpicker.com/p/FWRkK8
Price breakdown by merchant: http://ca.pcpartpicker.com/p/FWRkK8/by_merchant/
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor  ($1286.98 @ DirectCanada)
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler  ($89.99 @ NCIX)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard  ($232.00 @ Newegg Canada)
Memory: Crucial Ballistix Sport 32GB (4 x 8GB) DDR4-2400 Memory  ($357.35 @ DirectCanada)
Storage: Samsung 850 Pro Series 1TB 2.5" Solid State Drive  ($579.00 @ Canada Computers)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($151.25 @ Vuugo)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card (2-Way SLI)  ($879.99 @ NCIX)
Case: Thermaltake Chaser MK-I ATX Full Tower Case  ($164.50 @ Vuugo)
Power Supply: Corsair 860W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($234.18 @ DirectCanada)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($114.99 @ NCIX)
Total: $4970.22
Generated by PCPartPicker 2015-06-12 17:27 EDT-0400
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5204993
I would like it for gaming and some not very advanced programs for work.
I would like a 4k monitor included in $4000 U.S. and mouse keyboard and headset included also
so just reduce in my build from above the ssd to 256 gb (thats enough, maybe 512gb) and you'll get a monitor and a headset
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5205015
Total: $4970.22
Just no.
Currently roaming the forums in boredom
I like mice and keyboards and the sort
Formerly TheFlurryGames
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5205398
Just no.
Way too overkill, lol.  Get an i7 4790k or 5820k with 16GB of RAM, 500GB SSD, and a better case...  Thermaltake is okay, but I personally hate the look of their cases.
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5205412
For those wondering about the NEX PSU, the NEX PSU is made by FSP and under technical review (many sites) has proved to not be very good at all.  The EVGA GS/PS are made by Seasonic, and the B2/G2 are made by Superflower.  The GS/PS/B2G2 PSUs are rated much higher than the NEX.  People do this shit for a living, the information is out there.
Here is a useful little PSU resource:  http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
@kdmb13 @Stardar1
https://linustechtips.com/topic/385509-5k-build-help/#findComment-5205435
