I recently got an asus dg audio card but so far i dont belive that i can use it though because i dont think my motherboard being the asrock z87 oc forumla has the right pci for it. Can someone please confirm that i can not use this please?
Motherboard:  http://www.overclock.net/t/1428485/review-asrock-z87-oc-formula
Card:  https://www.asus.com/us/Essence_HiFi_Audio/Xonar_DG/
I run my own indie game company called Color Dragon Studios where we are currently making a 2d platformer game called Small Earth.
https://linustechtips.com/topic/385478-audio-card-incompatable/
Unfortunately your motheboard doesn't have any PCI slots, only PCI-e. They aren't cross compatible so you won't be able to use the card with your PC.
If you bought the card very recently you should be able to return it for a refund (if you haven't opened it or if your chosen retailer is nice enough).
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/385478-audio-card-incompatable/#findComment-5204436
Nope, it isn't compatible. The audio card uses a normal PCI x8 slot.
Your motherboard only has PCI-e lanes and PCI x1 slots.
CPU: I5 4690K@4.3GHz - Motherboard: Gigabyte Z97 Gaming 5 - GPU: Gigabyte G1 GTX 960 4GBRAM: 16GB HyperX Fury@1600MhzPSU: Cooler Master G750M (750W)Case: Corsair Carbide Spec-01SSD: Kingston HyperX 120GBHard drive: 500GB Western Digital
https://linustechtips.com/topic/385478-audio-card-incompatable/#findComment-5204448
It's a pci sound card and you only have pci-ex1 and pci-e slots.
What do you think?
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/385478-audio-card-incompatable/#findComment-5204449
