Wireless Network Adapter - PCIe or USB?
Lampy
I'm looking to do a build in the near future, and I live in a basement apartment, so I don't have access to the router. I'm looking into wireless cards, but tbh, I have no clue what I'm looking for. Does anyone have any experience with/recommendations for certain wireless adapters?
Any advice is appreciated. Thanks in advance. :)
What is ur budget for the card?
Not really a set amount, but I'm looking bang for the buck. Not too cheap, but I don't exactly wanna dish out more than $100 CAD either.
I would say that this would be a great choice:  http://www.ncix.com/detail/asus-pce-ac56-dual-band-802-11ac-41-96191.htm
Definitely an option. Is there a reason as to why you chose this one? Just so that I know for the future.
There is that thing where you can connect ur antennas so that you can get them into a better place and when you are on the go you can screw them directly to the card. And its Asus Quality
