This is my first time building a PC, just double checking. I currently have a Asus Rampage V Extreme Motherboard, I want to grab a Noctua NF-A14 FLX. Would that fan work with OC Panel and Fan Xpert software? Or would getting a Noctua NF-A14 PWM be the better choice?
I also have two Corsair AF140 Blue LED Silent Edition fans for Intake.
Just want to make sure it would get along with the OC panel / software and theirs no issue plugging them into my motherboard.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/385223-fan-compatibility-question/
i don't have a oc board so i'm not sure on that. fans really only come in 2 types, 3 pin and 4 pin. both you can connect to your motherboard. ok, i just looked at the oc panel thing, it has 4 pin fan connectors on it. 4 fans are ones with PWM, you can control them more finely with motherboard software or whatever software comes with the panel, asus is know to have decent fan software.
Ok Thanks, Just ordered the PWM fan.
