Sound Card Help: Moving my Sound Card into a new PCI-E Slot and Sound Quality is Being Affected
Solved by Zanthraz,
Found the problem. It must have been a bug with the sound card driver. When i installed the newest update, the louder pci-e slot system memory jumped from 50% to 70%. Since I have the Xonar driver controlling the system settings, it must have been reporting the wrong volume outputs between the pci-e slots. everything seems to be fixed. Thanks for the help guys.
Sound card drivers causing problems, wow. That never happens now does it
