I'm building two identical computers with a GTX 980Ti, an Intel i7-4790K, and a NZXT Phantom 530 White Case. I'm wanting to liquid-cool the CPU and GPU, and I've seen this cooling kit: EVGA 100-WC-S201-BR Watercooling Kit for Hadron Hydro and I know that this kit comes with a CPU block that is compatible. I'm getting this GPU block for the 980Tis: EKWB EK-FC Titan X Water Block (Nickel Plexi). The kit also comes with radiator, pump, etc.
I have a few questions:
  1. This comes with a radiator, do I need fans for this? If so, what size, type, etc..
  2. Will all of this fit in the case? (I can understand if you can't answer this question).
  3. Will I need any special fittings, special tubing, etc?
Thanks for your help!
https://linustechtips.com/topic/383628-help-liquid-cooling/
What size rad? Then i can recommend fans
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/383628-help-liquid-cooling/#findComment-5196895
