Help me build a pc!?
Go to solution Solved by Jacktastic-Mofo,
I know you wanted a monitor, keyboard, and mouse however I left those entirely for you to choose. This build is a beast and leaves plenty of room to get peripherals that suit your needs. It's got an i5-4690k and GTX 980 which will be plenty for any level of gaming you'd want to do at 1080p / 1440p within the next two years. I've also added a 250GB SSD for super fast boots and program loads. Of course you may not like the case selection but I chose it cause I really like the Corsair Obsidian line and being a proud owner of a 350D I can tell you with great confidence that the 450D is also a great case. Best of luck!
PC Part Picker Link ----------> Here you go! <---------- PC Part Picker Link
Hi! i want to build pc, but dont know what is the best for gaming. my budget +/- 1500 eur (all pc parts, monitor, mice, and keyboard)
So. about pc- i have 500gb hdd. and what i want= ssd for windows, geforce videocard (no radeon-i have bad experience with it), intel cpu, and motherboard, who supports things for next gen(for 2 years i will upgrade it)+ i want to overclocking possibilities.
i want ultrawide monitor or maybe 2 16:9 putted together
mechanical keyboard only
and great mouse for csgo and cod gaming (most of csgo)
PLEASE HELP ME WITH PC PARTS, I REALLY NEED YOUR ANSWERS!  :D
https://linustechtips.com/topic/383626-help-me-build-a-pc/
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179517
First of all: You can't play CS:GO in 21:9. That's why one of my friends sold his ultra wide monitor soon after buying it. I'd prefer 2 usual 16:9 monitors. They still offer plenty of space and are (in most cases) cheaper.
For a mouse you have to kind of decide for yourself. I personally use a Roccat Kone Pure Optical and I really like it. On 400 dpi and an ingame accuracy of 3.0 it runs smooth and pretty accurate.
But it might not fit for you. The best solution would be to visit a bigger tech store and try out some mice.
For mechanical keyboards it's mostly the some, though most people will recommend you one of the corsair models. (K70 / K90) They are both well built and house cherry MX switches. You might also thing about a Logitech G710+/910 if you are more on the Logitech side of things.
I'll look into the PC parts part a little later, if nobody has already done that so far.
I once had one of these, now I've got this.
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179535
What store?
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179538
I would go with a build like this:
PCPartPicker part list: http://de.pcpartpicker.com/p/NjZnhM
Price breakdown by merchant: http://de.pcpartpicker.com/p/NjZnhM/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (€242.87 @ Amazon Deutschland)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€34.70 @ Amazon Deutschland)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  (€88.08 @ Home of Hardware DE)
Memory: Corsair 16GB (2 x 8GB) DDR3-1600 Memory  (€99.79 @ Home of Hardware DE)
Storage: Transcend SSD370 256GB 2.5" Solid State Drive  (€89.90 @ Amazon Deutschland)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  (€358.57 @ Amazon Deutschland)
Case: Corsair 200R ATX Mid Tower Case  (€67.48 @ Home of Hardware DE)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (€94.49 @ Amazon Deutschland)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit)  (€92.98 @ Home of Hardware DE)
Monitor: LG 25UM57-P 60Hz 25.0" Monitor  (€216.44 @ Amazon Deutschland)
Keyboard: Cherry G84-4100LCMUS-2 Wired Slim Keyboard  (€49.90 @ Amazon Deutschland)
Mouse: SteelSeries Sensei RAW Wired Laser Mouse  (€48.70 @ Amazon Deutschland)
Total: €1483.90
Generated by PCPartPicker 2015-06-09 21:28 CEST+0200
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179575
and whats the layout of 2 monitors? vertival or horizontal, does razer mechanical keyboard worth buying?
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179885
Thank you for your help!!!! i really like it, but i think i want asus motherboard, cuz all options and overclocking <33
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179929
Well your free to change it up! I have to tell you though Gigabyte has an overclocking desktop application called Easy OC, and when I used to have a Pentium G3258 it allowed me to one click OC it from 3.2ghz to 4.9ghz. It is freaking awesome and I highly recommend it, as it takes all the guess work out of overclocking and makes it generally safer.
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5179994
Horizontally.
I can't say much about the razer one. I never really used Razer products. You might have to try the switches, because they use their own switches since a few years.
https://linustechtips.com/topic/383626-help-me-build-a-pc/#findComment-5180065
