I am a first time pc builder.  I have got just about everything nailed down for my pc build except for cooling.
My build at present is here, PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£221.94 @ Aria PC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  (£115.99 @ Aria PC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£71.94 @ Aria PC)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card  (£289.99 @ Aria PC)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case  (£79.87 @ CCL Computers)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer  (£13.06 @ CCL Computers)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£75.34 @ CCL Computers)
Total: £1093.10
Generated by PCPartPicker 2015-06-09 17:32 BST+0100
I am looking to do some overclocking of the CPU to use this as both an editing and a gaming rig.
as you can see it is still the stock intel heatsink with no additional fans.  any suggestions on cooling solutions, allowing me to overclock the CPU whilst trying to keep the system as quiet as possible.
https://linustechtips.com/topic/383553-cooling-help-for-first-time-build/
Total: £1093.10
There's many cpu coolers, alot of people will recommend different products, they mostly have the same performance. Just look up reviews and pick one you like. Corsair, nzxt, cooler master, etc.
What's your budget for a CPU cooler? I can recommend some for different price points, but it's not useful me suggesting a Be Quiet! pure rock when you can afford a dark rock pro 3.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
if you would want a silent build i would go for the define s (there is one straight pad the airflow is taking so no "wind" noises). and use a external dvd drive (you will come out cheaper if you add it all up)
for the cooling if you really want ultra performance go for watercooling Corsair H100i or another 240mm radiator. (this one will make more noise then most aircoolers when you want really low temps)
if you want really low noise i would recommand Scythe Mugen 4 or Be Quiet Dark Rock Pro 2
i got the scythe mugen with an extra fan and i dont even need to ramp up the rpm to get under 65 degrees (good airflow inside case too)(same cpu) beyond the point you can hear them. with a nice 4.7Ghz @1.35v overclock.
good luck my friend
hakuna matata
If you want something very basic and cheap, its 212 Evo. For bit more you can get Dark Rock 2/3 or go for Noctua and Phanteks. I personally wouldn't spend for AIO unless you are for looks.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
