i'd buy more of the same fans, i'm sure someone can tell you what fans they are.
EDIT: @nissen22 follow your topics, button for that is in the top right corner.
I know what fans they are. I was just thinking I should get something more powerful. I'm going to have a kraken x61 on top and two 980tis in sli, so I bet it will be a bit hard to get positive pressure.
https://linustechtips.com/topic/383399-define-s-front/#findComment-5176612
i have a define R5, and the only airflow is the two included fans in the front, and i dont hear a difference between max speed and min speed, while they also generate quite a bit of airflow.
https://linustechtips.com/topic/383399-define-s-front/#findComment-5176632
Ap123 would be ideal for the front of that case due to it's direct airflow.
Ap141 if you need 140mm
https://linustechtips.com/topic/383399-define-s-front/#findComment-5176721
The fans that come with the Define R5/S are very good for the price as well.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
https://linustechtips.com/topic/383399-define-s-front/#findComment-5176903
