Hey Guys,
Im a first timer building a pc, and I want to build a gaming/working pc. Im currently living in Bangkok, Thailand. My price range is around $2000usd. Note that the price for the parts in Thailand might be different than in the us or other part of the world. Im planning to build this as soon as I get back from Europe which with be in mid August.So any help or suggestions would be very appreciated :):D
Here the parts that I picked on pcpp
http://pcpartpicker.com/p/PGtwJx
https://linustechtips.com/topic/382913-my-first-gamin-rig/
Hey Guys,
http://de.pcpartpicker.com/p/X6pyrH
what games do you want to play?
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5169888
Hey Guys,
It looks good. I do have a couple of points:
1. The NH-D15 is a pretty large cooler, so I'd make sure it fits in your case, on the subject of cases...
2. I don't hear great things about Zalman. Something like a Fractal Design Define R5/S might be a good alternative, but I'm not sure of the compatibility of that case with that air cooler, so don't take my word for it.
3. The Gigabyte GTX 970 is a behemoth of a card. Make sure this also fits in your case, as hard drive cages may prove obstructive.
4. I also don't hear great things about the Corsair power supplies, look up reviews for power supplies on JonnyGuru. I've read that the EVGA 750 G2 is an excellent power supply.
5. The monitor seems nice and all, but this rig is WAY too powerful for 1080p @ 60fps. I'd recommend a 1440p 60Hz panel instead (I run a 4690K with a GTX 970 and have excellent performance at 1440p), or a 1080p 144Hz panel if you're a competitive gamer.
GTV , The Witcher 3, BattleField, etc....
I'd go with 1440p, though. If you're feeling adamant about running a 1080p 60Hz panel, the rig your planning is a bit overkill. You might as well save your money.
6. This is more of a personal thing, but I find optical disk drives a bit redundant these days. If you have a lot of optical media, then it's a good idea. But if you don't, it's kind of a waste of money.
Other than that, it looks like an excellent build.  :)
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5169958
Thank you for your input. Do you have a recommended monitor? I will have a look for a new case and power supplie.
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5170065
I recently bought the BenQ GW2765HT, which is a gorgeous 1440p IPS panel. I can't recommend that enough. Some people complain of the low response times of IPS panels, but honestly, I don't see it. It could be due to my PC gaming inexperience (relatively short at approximately 4 months). Furthermore, if you're worried about running games at 1440p with your setup, don't be. I also have a 4690K and a GTX 970, both at stock clock, and I run 1440p like a motherf****** dream.
EDIT: This is also including demanding games like GTA V, of which I run with the settings cranked at 60 fps consistently, and Crysis 3, which I run cranked at 50 fps consistently.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5170128
Hey Guys,
I've just noticed the 'working'. What type of work is this?
If it is editing and rendering, you may find more value in an i7-4790K. However, if it's more skill based and not related to computation/content creation, an i5 would be a mighty fine choice.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5170216
The RM 750 isn't a great choice. For the same price, get EVGA G2. It is FAR better made internally,  has a SWITCH for Eco mode, it is not just stuck on. It is overall better quality, and also has 10 year warranty. It is also cheaper - considerably.
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5171766
1440p Monitor in thailand is way overprice. :(
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5174664
switching to the EVGA G2 now, thanks!!!
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5174667
The RM750 is fine Although so is the EVGA G2 I have the RM 750 and you're not going to see any problems with it, at least not for so many years you'd have a new pc by then xD
CPU: i5-4690K @ 4.0GHz GPU: Gigabyte Gtx 970 WindForce MOBO: Gigabyte Z97 Gaming-3 CASE: Corsair Carbide 200R PSU: Corsair RM750
RAM: Corsair Vengeance 4GBx4  MOUSE: CM Mizar KEYBOARD: Logitec G110
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175143
Cheers Bro, but I like that 10 warranty aye lol
Oh yeah the RM750 is only 5 but I figure I'll have a new pc completely in 3-4 years
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175431
Grab your OS from http://www.reddit.com/r/microsoftsoftwareswap/to save a bunch of money.
Thank you so much for posting this... I was going to buy windows 8 next week for my new pc, I just saved myself $120... Bought it for $10 xD
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175498
If the 1440p monitors are super expensive, it might not be a bad idea to downgrade some of your parts to save some money.
At 1080p, a GTX 970 is way overkill. You could argue that it will last longer as games get more demanding, but then you haven't really seen an immediate return on your investment. I'd recommend a GTX 960 or R9 280X instead.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175610
Don't get the RM, despite many not having problems, many do.
970 is perfect for 1080p, 960 won't Max everything out
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175617
No a 970 is not WAY over kill for 1080p xD
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175638
Never seen anyone have problems with it
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175639
read a lot of reviews that ppl are having problems with it, the EVGA G2 has very good review on it.
3.5G won't be an issue for 1080, no.
G2 is better in every way.
https://linustechtips.com/topic/382913-my-first-gamin-rig/#findComment-5175688
