Hello Guys,
at first i'm sorry, my english is bad. I'm from Germany.
I have 2 Questions:
1. Should i buy the h100i or the h100i GTX ?
and
2. How should i clean the CPU from the Thermal Compound ?
Thank you.
Michael
Air coolers at the same price are still better than h100i, but if u're running into a problems with free space - it's fine.
If u're replacing a cpu cooler, u need to apply new thermal compound on it.
https://linustechtips.com/topic/382777-cpu-cleaning/#findComment-5168089
Hallo,
99% isopropyl alcohol for cleaning off thermal paste. (70% is also fine)
Watch LinusTechTip's video on cleaning thermal paste.
When I make a post, unless I am the original poster or ask for a reply, don't bother replying or quoting me because I don't read them.
https://linustechtips.com/topic/382777-cpu-cleaning/#findComment-5168104
I would go with the 100i GTX. This is primarily due to the fact that it uses a different block and tubing which improves on the prior design. I prefer the look of the new tubes they look premium.
In terms of cleaning well its quite simple. You can get a micro fiber cloth and isopropyl alcohol and put some alcohol on the cloth and wipe off the residue. I use 99% isopropyl alcohol but you can use 75% as well.
99% Isopropyl Alcohol
http://www.frys.com/product/3936318?site=sr:SEARCH:MAIN_RSLT_PG
Microfiber cloths
http://www.frys.com/product/6714995?site=sr:SEARCH:MAIN_RSLT_PG
https://linustechtips.com/topic/382777-cpu-cleaning/#findComment-5169173
