I currently have a GTX 760 2gb, Fx 4350, 500w psu and 8gbs of ram. I have £300 from my birthday and was wondering what i should buy to be able to run games such as arma or newer released games on higher settings than I can now. Please leave suggestions on what i should buy in order to get the maximum performance possible.
https://linustechtips.com/topic/382412-upgrade-advice/
If you really want to upgrade, you can always upgrade your CPU or your graphics card. You can spend all of your money on a new gpu like the GTX 970, but your processor can bottleneck your performance.
• OS: Windows 10/10 Pro  • SSD: Samsung 256GB 850 Evo Series *  • HDD: Seagate 1TB  • GPU: MSI GeForce GTX 1070 GAMING X (SLI)
• CPU: i7-4790K OC 4.7GHz Quad-Core Processor • Case: NZXT H440 (Black/Red) • PSU: EVGA SuperNOVA NEX 650W
• RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory • Mobo: MSI Gaming 5
https://linustechtips.com/topic/382412-upgrade-advice/#findComment-5163546
Is a good psu or a Chinese gray thing.
https://linustechtips.com/topic/382412-upgrade-advice/#findComment-5163579
Ok I don't think my psu would have enough power for 970 and the bottleneck would be quite bad any other suggestions?
http://uk.pcpartpicker.com/p/TMkDkL The 760 should be good for 1080p mid range gaming. So upgrade that to a 970 later down the road.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/382412-upgrade-advice/#findComment-5163599
Cooler master
Cooler master can be good and dodgy.. really depends on the model. But any half decent 400W (or even less) can handle a 970.
Consider selling your whole rig for about £300 + and I'll spec you a new one that will knock it's socks off for £600+.
Here is one I threw together the other day... Add another £60~ for a HDD..
Can go cheaper for a 960 if budget is tight..
Ideally there would be a HDD and a slightly more powerful PSU if you ever want to go SLI.. As said, things can be changed buit this is your best option *IF* you can get another £350 by selling your current rig
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  (£89.90 @ CCL Computers)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  (£89.99 @ Novatech)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  (£68.98 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  (£258.98 @ Amazon UK)
Case: Fractal Design Define S ATX Mid Tower Case  (£57.65 @ More Computers)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (£37.20 @ More Computers)
Total: £647.13
Generated by PCPartPicker 2015-06-07 15:52 BST+0100
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/382412-upgrade-advice/#findComment-5163649
You'd need to look up specific benches for an i3 and 970 But it'll kill your current rig with a new gpu or cpu or mid range both upgraded.
As for cooling, the case is great and all the components are very efficient so cooling isn't a problem.
A build like this I would say will last about 3 years before you'll need a refresh (Depending on you own usage and needs) but then it's a drop in upgrade for GPU and CPU and ram if needed.. you'll also be able to use i5/i7 unlocked processors which stomp all over anything but the highest clocked, water-cooled AMD (without overclocking them)
For reference.. (note that this is a slower and older i3.. you'll get better than this) That said.. it looks like Arma doesn't really favour 1 camp over the other but many other games would benefit.. Take this as you will and decide for yourself.
https://linustechtips.com/topic/382412-upgrade-advice/#findComment-5164019
A 500W PSU is enough for one 970. I recommend getting a 8370 with your mobo instead of the 970 right now, because I suspect the 4300 may be holding back the 760
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/382412-upgrade-advice/#findComment-5166322
