Okay so i've been planing on building a computer for months now, I've been researching and what now and i got this build: http://pcpartpicker.com/p/ZdHdP6
I am on a budget so i cant go higher than 1k. My question is, IS my build good for the price, Did i make the right decision on the parts? the card i can get for 300 used, Or just buy it new for 400.
Pretty sure i can just take out some drive bays for the card and buy a 6 pin cord and i'll be all good.
Edit: I do plan on ocing a bit, If heat is a issue i can always liquid cool later, But for now i wanna try the fan cooling out.
What's up with that 290x price?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
Everything looks good. the LGA1150 socket gives upgrade (and downgrade) potential. And this:
TBH I think you can get a better case for cheaper eg Fractal design r4/5/s
That NZXT case is so overpriced
How to create a strong password
Size does not matter; it's how you use it
I would get this build instead and upgrade to SLI 970's in the future.
PCPartPicker part list: http://pcpartpicker.com/p/NPfN4D
Price breakdown by merchant: http://pcpartpicker.com/p/NPfN4D/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: be quiet! PURE ROCK 87.0 CFM Sleeve Bearing CPU Cooler  ($33.99 @ NCIX US)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard  ($94.99 @ Micro Center)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($94.99 @ Amazon)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($67.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($319.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case  ($54.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ NCIX US)
Total: $1006.90
Generated by PCPartPicker 2015-06-07 16:22 EDT-0400
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
The case is sexxyy tho! Lol yeah i'ma look for a diff case than, I want something with green led's, I have a theme going on.
You could buy a strip of green LEDs that connect to usb and run them round your case. Linus did that once
