What speaker set do you have? I have a Dell 5650 5.1 Surround speaker set, had that happen when the volume control died, now I'm locked at max vol. Could be something similar.
Edit: I don't use integrated anymore, so not sure what setting it could be. Also make sure you don't have any malicious software or anything conflicting software.
https://linustechtips.com/topic/38237-volume-drop/#findComment-491679
check your volume levels
youtube volume
program volume
master volume
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/38237-volume-drop/#findComment-491694
Click the speaker icon in the Notification area, then click the Mixer link. Check to see if t0wer's suggestion is the problem.
https://linustechtips.com/topic/38237-volume-drop/#findComment-491715
