I have a GTX 660ti made by Palit and I am getting temps of 94oC at idle with 30% fan speed is there something wrong with my card?
https://linustechtips.com/topic/3813-660ti-heat-issue/
I have one intake and one exhaust, my cpu is around 28oC atm. Im using the software which came with the card i think its called thundermaster. Usually it displays around 30oC for idle at 30% fan speed it may be a glitch in the software so im going to restart and see what happens. I've only had the card a week :/
https://linustechtips.com/topic/3813-660ti-heat-issue/#findComment-46953
did you OC it?? :/ instal MSI afterburner, it works whit all cards as OC tool and you can keep track of your GPU temp.... se if it is showing such huge temp in idle...
but Im guessing its just a bug.... I saw a -113C for hdd temp once on a PC that come to me for an system upgrade :) loled so hard...
https://linustechtips.com/topic/3813-660ti-heat-issue/#findComment-46960
I restarted and it has fixed itself must have been the software glitching out or something. Thanks for the help im gonna install MSI afterburner now that will probably be a bit more reliable. Yeah that HDD temp is so cool surprised it can even spin at them temps. :)
https://linustechtips.com/topic/3813-660ti-heat-issue/#findComment-46973
bad sensors... they can make so much mess...
https://linustechtips.com/topic/3813-660ti-heat-issue/#findComment-47419
on 30% fan speed? or your fan is dead, or the read-out is wrong (by component or user ;)) or your fanspeed is set to 30% and not on automatic.
"People assume that time is a strict progression of cause to effect. But actually from a non-linear, non-subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey stuff."
Dont understimate my skillsz, you might look foolish.
https://linustechtips.com/topic/3813-660ti-heat-issue/#findComment-47896
