Don't know if this is were to ask or if it was mentioned in the video, butttttttt does anyone know when this case is going to be released for sale for consumers? From what I see it is a pretty cool case and looks pretty good.
https://linustechtips.com/topic/381247-cm-mastercase-pro-5/
I dont knw when it will be released.....BUT I'M ADDICTED TO THE
Cooler Master Mastercase Pro 5
Intel i3-4150 3.50Ghz | MSI B85M-G43 | HyperX Fury 8GB 1866Mhz x1 | Intel HD 4400 | WD Caviar Blue 500GB , Samsung 160GB | Odyssey 450W | AOC E950Sw 18.5In | Windows 10 Pro | Zebronics Armour 2
https://linustechtips.com/topic/381247-cm-mastercase-pro-5/#findComment-5149869
I'm just hoping they make a full tower version of it.
I'm guessing you will be water coolling then? I don't see any point to full towers except for more room to watercool.
https://linustechtips.com/topic/381247-cm-mastercase-pro-5/#findComment-5152100
I don't know when it's coming out, but I know for sure I want one as my next case! t's going to be a modders and watercoolers dream, especially with that midplate preinstalled.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/381247-cm-mastercase-pro-5/#findComment-5152119
Yeah I just hope it is at a good price (US) because the most expensive case I am looking at right now went up to $120 and I don't really wanna go higher than that but I have a feeling it will be $150 range.
https://linustechtips.com/topic/381247-cm-mastercase-pro-5/#findComment-5152202
Considering there's 3 different versions of it, a basic version, a pro version and a maker version, it makes me think the cheapest may possibly be around the $100 mark, although closer to $120 is more likely. So long as it's below £100 I'll probably look at getting one myself.
PCs
https://linustechtips.com/topic/381247-cm-mastercase-pro-5/#findComment-5152247
