Hey guys so I have this PC Build planned out, it will be used for gaming and for flight sims. Just need to know what ye guys think, I'm slightly concerned about temps when I overclock. Let me know what ye think, thanks in advance guys! :)
==========> http://uk.pcpartpicker.com/p/BVzTxr
https://linustechtips.com/topic/380739-need-advice-d/
I've got 2 doubts with that system:
A. Tiny Noctua cooler while having room for a huge one.
B. Storage?
@12dohertynoel : Follow your topics :P
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/380739-need-advice-d/#findComment-5144025
looks fine for gaming, how harcore are the flight sims? also get bigger cooler and a hdd
Builds:
https://linustechtips.com/topic/380739-need-advice-d/#findComment-5144027
go for a hyper unless you want quiet cooler
https://linustechtips.com/topic/380739-need-advice-d/#findComment-5144038
B. Storage?
The reason for the small cooler is caus of my budget, and i belive its still better than a stock cooler? :) I already have a 2TB external hardrive, Forgot to mention that, my bad! :)
The flight sim is Flight Simulator X, it's really CPU intensive which is why I need to overclock! :)
https://linustechtips.com/topic/380739-need-advice-d/#findComment-5144067
http://uk.pcpartpicker.com/parts/partlist/
I don't know what your budget is but this is what I'd recommend :)
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/380739-need-advice-d/#findComment-5144075
I don't think you changed anything! :)
actually you didnt give me the correct link :)
Ugh, I didn't give you the permalink :L
I deleted the build afterwards aswell. I'll make it again when I'm done making another one for someone else.
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/380739-need-advice-d/#findComment-5144092
