I am trying to port forward for a server for the new game Ark:  Survival Evolved.          I have port forwarded on the same router for a minecraft server, but for some reason it won't work with ark.  For minecraft the port is 25565.  I will port forward that and it will work.  but if i go to can you see me.org it says that the port is not open.  the same thing happens with the ports i need forwarded for ark, but my ark server won't work.
Help
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/380535-port-forward-help/
Which IP address are you using?
https://linustechtips.com/topic/380535-port-forward-help/#findComment-5141232
do i have more than one?\
Try using your public IP address when port forwarding. You can find it by Googling "Public IP address."
https://linustechtips.com/topic/380535-port-forward-help/#findComment-5141251
i don't get an option to use an ip when i port forward.  I get the option for the port to forward, then to select a device.
https://linustechtips.com/topic/380535-port-forward-help/#findComment-5141279
Why not just use Hamachi? Port forwarding just creates alot of headaches and when you're finally done doing it, there's some security risks.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/380535-port-forward-help/#findComment-5141300
  • 2 months later...
