Hi I'm alittle new to forums but I have been watching linus for awhile. I just wanted to know if the parts I picked for my new build is good enough for 4k gaming at 60fps or 1080 at 60fps or greater. I'm planning on doing a bit or streaming, gaming, coding and several graphic stuff (autocad, sony vegas, after effects and photoshop). Also should I get the asus extreme instead of the deluxe?
Parts list:
http://pcpartpicker.com/p/WPDsrH
Ps: I might also want to try doing a custom loop so if anyone have any tip or parts list for the custom loop can you please suggest it
https://linustechtips.com/topic/380040-build-help/
Parts list:
Think about it: you have a 6 core CPU's and 2 980's.That's a beast rig.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/380040-build-help/#findComment-5134659
so im guessing the part list i picked was good
yes
https://linustechtips.com/topic/380040-build-help/#findComment-5134682
And this is why i want to be rich
You already have a GTX 970, and a 4690K. You can always upgrade you know.
https://linustechtips.com/topic/380040-build-help/#findComment-5134684
do you have any recommendation on where to learn the part list of a custom loop or can you provide a list for the parts of one?
I'm sorry, I can't help you in that, as I am just starting to get into watercooling. All i can say is, you need a radiator, a pump, a reservoir, and a CPU/GPU block. EKWB makes good watercooling parts.
https://linustechtips.com/topic/380040-build-help/#findComment-5134701
Okay thank you, I've only seen people done watercoolering but never bought the parts myself, and thank you for the tip
https://linustechtips.com/topic/380040-build-help/#findComment-5134715
If you are doing 1080p 6 cores is way overkill i7 4790k is enough, also 16 gb of ram is enough
i was planning on having it overkill at the start since I already have 2 standard builds and wanted to got all out with the new one, making it into a table mod also. I just basically wanted to know if the specs were good enough because I still consider myself a beginner at part picking...
https://linustechtips.com/topic/380040-build-help/#findComment-5134842
The motherboard is perhaps unnecessary, you could easily get away with a $200 board with less features but nothing that you would likely notice
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/380040-build-help/#findComment-5135804
