so i just finished building my new computer http://pcpartpicker.com/p/87tCP6and i am unable to connect to the internet via wifi or ethernet. I know my wifi is working because im on it now, and i used my ethernet last night. I bought my OS off reddit/r/microsoftsoftwareswap, could that be whats causing the problems? I have turn my computer on and off a few times anything else i can try?
https://linustechtips.com/topic/379682-wifi-help/
You LAN drivers arent installed. Go to device manager and check.
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/379682-wifi-help/#findComment-5130686
sry for being a complete noob but,where would i find the drivers and how would i install they, do i install it the same way as i did windows(using a flash drive)
Your parts list doesn't include a WiFi card and that mobo doesn't list one on the screens I can see?
your WiFi card should have come with a driver disk, this should get you started. You will need to put drivers on for all components to go through your boxes and run each of the driver installs.
Then go to the website for each one once you have it working and get the newer ones that came out after they put the bits in the box.
https://linustechtips.com/topic/379682-wifi-help/#findComment-5137638
