GPU's are rated to go up to much higher temps. That seems fine. Personally I would change the fan curve, and actually make it less extreme for quieter performance at a higher temp cost.
“I don't like country music, but I don't mean to denigrate those who do. And for the people who like country music, denigrate means 'put down'.” - Bob Newhart
Remember kids; just because Linus has a video on it, doesn't mean that its the best choice Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/379388-gtx-970-temps/#findComment-5126700
Is 75 degrees on an MSI GTX 970 Gaming 4G @ 1450 MHz good?
I was running it in Witcher 3 at ultra settings and it left me worry a little. The fan speed was at 90 percent.
Improve your case airflow. I live in a tropical, humid country and my 1524/2008 gtx 970 gaming 4g is only hitting 68c with 82% fan speed.
https://linustechtips.com/topic/379388-gtx-970-temps/#findComment-5126804
