I'm working on a computer using pcpartpicker and I'm trying to get it all done and rdy to go so i know how much i need in the bank... *I'ma be broke i know that xD* how ever I'm kinda at a STOP sign with the Graohics cards with 3 main questions.
1. is it worth? i was going to go with the GTX Titan X but thanks to linus I'm wondering if its worth it or should i just get the 980 TI when it comes out? look at my set up :)
2. Should i even get 2? would 2 980 TI's be better or would the VRAM from the Titan be better or hell would it be better just to get 2 titans?
3. Water cooling it? i am going to do a custom water cooling loop on my cpu but should i do the work for the GPU as well or are they fine on there own? again look at set up to help :)
Set up. still picking out the monitors *any suggestions would be awesome* but i plain on having 2 side monitors around 24.0 and the middle main monitor 27.0 i do not plain on using 4k,
main monitor would ofc be for games and the side ones for google chrome and streaming software. 16GB's of ram, Mother Board -Asus MAXIMUS VII HERO ATX- still not sure if that's the best choice but still looking, again any suggestions help. and ofc a 1 TB SSD and 3TB HDD.
did have Pcpartpicker set up but lost the link :( and want the questions taken care of before i rebuild it.
i Don't want to waste money but if it means not lagging I'm willing to spend :)
https://linustechtips.com/topic/379230-graphics-cards-help/
a single 980ti. You wont use 12gb of vram in gaming.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/379230-graphics-cards-help/#findComment-5124528
1. 980ti doesn't worth get 2 titan x instead
2. water cooling yeahu cant under estimate it hh xD lol
3. i say get ur room temprature below 16 degree by turning on the air conditioner ha lol xD..
........................ :D:P
https://linustechtips.com/topic/379230-graphics-cards-help/#findComment-5124766
umm not fully sure if you're serious duo to the air conditioner thing and the spelling being worse then mine x.x
https://linustechtips.com/topic/379230-graphics-cards-help/#findComment-5125006
