I'm new member to this forum, but not a new member to linustechtips youtube channel.
can you please advice me
Here is my current setup
CPU: i5 2500k OC 4.5Ghz (custom liquid cooled)
MB: Asus P8-Z68-v pro
Mem: G.Skill sniper 16GB
GPU: Geforce GTX 580 (custom liquid cooled)
Display: HP w2408h 1080p 60-75Hz
PSU: Thermaltake tough power 1000w (very old stuff :P )
Disk: 256GB SSD sata3+ 1TB 7200rpm
I would like to play games at 1440p (want to get a 120hz or 144hz monitor) at highest possible settings for most of the games, I also use my computer to build linux vm's and practice/play with my job related stuff like openstack, docker some application server installs etc.
my budget for the upgrade is around $3000-3500 .. so I would like to get a enthusiast-performance kinda setup
Here are my question(s):
1. what graphic card(s) should I get ? I was planning to get 980 Ti's in SLI .. what do you guys recommend ? will these bottleneck my CPU
2. which display is good at 1440p at 120hz-144hz with gsync ?
3. should I upgrade to Haswell-e/X99  or IvyBridge-e/Z97? if yes which processor/MB/GPU ?
4. should I upgrade my PSU (it is working just fine)  ?
please advice guys, thanks in advance
https://linustechtips.com/topic/379162-need-advice-with-upgrade/
1. go for a single one, then SLI if you feel you need it in the future
2. Personally, i like ACER, but thats just my preference
3. I would say go for LGA 1150, as its about to get a whole new line of CPUs, and DDR4 and X99 MoBos are a lot of $$$$
4. Profit
that PSU is fine
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/379162-need-advice-with-upgrade/#findComment-5123643
4. Profit
that PSU is fine
Forgot to mention, the CURRENT LGA 1150 CPUs I recommend are the 2 Devil's Canyon unlocked CPUs, the I7 4790k and the I5 4690k, but Broadwell is just around the corner.
Solitaire.
https://linustechtips.com/topic/379162-need-advice-with-upgrade/#findComment-5123658
Go for a 4790k z97 motherboard and one 980ti PSU is okay, for the monitos grab an ASUS ROG or a BENQ
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/379162-need-advice-with-upgrade/#findComment-5123711
http://pcpartpicker.com/p/FctYYJso something like this? Hmm I added a another 8gb Stick just because why not? Could probably make it an extra 16 if you want and eather 1600 or 1866mhz whatever speed yours is at. Added a 500gb SSD for games your play the most on steam like gra v far cry 4 ect ect... A new mobo, supports 4-way SLI. Why not? Plus... I picked the superclocked blow cards because they'll be in SLI so less heat for your PC. :)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/379162-need-advice-with-upgrade/#findComment-5123744
Thank you all for the advice, I heard that LGA 1150/Z97 is pretty much a dead socket and is not going to receive any new CPU's
and the new Broadwell line up is going to be on a new socket LGA 1151 ? I don't know how true the news is. If I upgrade to a new CPU/MB I want it to be a future proof (I feel like a idiot saying those words already ;) )..
https://linustechtips.com/topic/379162-need-advice-with-upgrade/#findComment-5124261
