My fans are speeding up without having any program open, im in the desktop doing nothing and they increase their speed for 3 seconds and then lowering it again. Whats the problem? How can i fix it?
Mobo: Gigabyte UD4 x99 BIOS: F12
Fans: CoolerMaster
If you need any information to help me with this problem, let me know.
Thanks
https://linustechtips.com/topic/378784-fans-speeding-up/
Fans: CoolerMaster
Thanks
What are your CPU temps?
i7 8086k @ 5.3Ghz / 32GB DDR4 Trident Z RGB @ 3733Mhz / Aorus GTX 1080 11Gbps / PG348Q
https://linustechtips.com/topic/378784-fans-speeding-up/#findComment-5118489
