Hi,
I just bought an H80i for my first build, but I also bought some PK-1 Thermal Paste...
So my question is this:
Is 90%+ Isopropyl alcohol enough to clean the pre-applied TIM on the H80i, or should I spend $14 on the ArctiClean stuff???
Any suggestions/recommendations would be great!
Thanks,
4Strings
ConsTR(4)uct:
  • CPU
    Threadripper 1900X @ 4.0GHz
  • Motherboard
    Asus PRIME X399-A
  • RAM
    32GB Crucial Ballistix Elite @ 3466MHz
  • GPU
    MSI GTX 1080Ti Gaming-X 11G
  • Case
    SilverStone Fortress FT02
  • Storage
    1TB Samsung 960 EVO + 500GB WD Blue SSD + 2x 4TB WD Red (RAID1) + 3TB HGST Deskstar NAS
  • PSU
    Corsair AX760i
  • Display(s)
    2x Acer Predator XB271HK
  • Cooling
    BeQuiet! Dark Rock Pro TR4
  • Keyboard
    Logitech G710+
  • Mouse
    Logitech G502
  • Sound
    Propellerhead Balance + Bose Companion II + AKG K7XX
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/3783-removing-thermal-interface-material/
also mentholated spirits works too just don't get it on the pcb
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
As stated above there are many ways to remove the TIM but my question is why the tim on the H80i is good (not as good as other stuff but its still good enough) i just don't see a reason to do it unless your going to but some really crazy stuff like the liquid metal.
Isopropyl will do the work. I personally used 95 % alcohol. Make sure to use a microfiber cloth. I didn't have one laying around, so I took the one that came with one of my sunglasses. :D
AMD FX-8350 // ASUS Radeon R9 280X Matrix // ASUS M5A97 Pro // Corsair Vengance 8GB 1600MHz // Corsair RM850 PSU //  WD Green 2TB // Corsair H60 // Cooler Master Elite 430 // KBParadise V60 MX Blue // Logitech G602 // Sennheiser HD 598 + Focusrrrrite 2i2 + MXL V67 // Samsung SyncMaster 245BW 1920x1200 // #killedmywife  #afterdark  #makebombs #Twerkit      "it touches my junk"   linus 2014
