I have a 64TB NAS that uses FreeNAS to store data from my home computers.  I have two PCs connected to the network via Ethernet and 4 connected via WiFi.  How should I setup my NAS so all my computers cam access it?  I'd really like to see an As Fast As Possible on NAS and server setups, like the one in the new office and the setup in the house.
https://linustechtips.com/topic/377642-home-diy-nasserver/
Hey VijayAT123 and welcome to the community :)
You should connect the NAS to the router to which all other devices are connected. Usually the OS has a guide on how to set it up in order to be visible for other devices on the same network. Here's something that popped up on the internet that might be helpful: http://doc.freenas.org/9.3/
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/377642-home-diy-nasserver/#findComment-5108006
An "As Fast As Possible" would be exactly what you just said.
Have a central data store
Connect your computers by wifi or ethernet to the network
Configure the NAS to share to the computers.
The problem is, there are so many OS's and NAS Interfaces, it would be like an hour long video to cover them all for 'basic setup'
What you need to know for FreeNAS and for Windows sharing, is how to setup a Samba (SMB) share via CIFS.
http://doc.freenas.org/9.3/freenas_sharing.html#windows-cifs-shares
https://forums.freenas.org/index.php?threads/cifs-windows-sharing-guide.20948/
If you have a network that you often have Guests on, then you also might want to think about advanced access permissions to the share.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/377642-home-diy-nasserver/#findComment-5110758
