Question regarding shutdowns and bootups.
Go to solution Solved by JMSOG,
I've been on forums for almost ten years now, and I have NEVER seen responses to a topic this fast...I think i might like it here :P
I just gave her the URL for this topic so she can make her decision...Believe it or not, in our debates on this topic in the past, the power bill never really came up...Might be a little more important now, since it will be a 600 watt PSU xD
Thank you all!!!
EDIT: also never seen this "mark as solved" feature...
So...My mom's old AIO computer just died after about 4 years of use. A long time ago, a friend of hers told her that one of the most damaging things you could do to a computer is to shut it down and boot it up. As a result, she would routinly leave it on for litterally months at a time.
Since it died, I put together a build for her (no hard drive, just a 1tb SSD, I don't know if that makes a difference), and the last few parts are going to arrive tommorow. So...before I present her with this brand new computer, I have to ask...
...Is it safer to leave it on than to shut it down overnight...? Factoring in performance overall and lifespan of the components.
My Build, "Helios"
CPU: 5950x with Noctua NH-D15
GPU: MSI 2080ti
Case: BE QUIET! Dark Base 900 Pro
Storage: Samsung 970  pro 500gb (boot drive), unknown 2tb Seagate drive, 4tb WD Black drive
PSU: Corsair HX1000i
RAM: (4x8) Trident Z RGB
Remote PC Starter Kit
https://linustechtips.com/topic/377315-question-regarding-shutdowns-and-bootups/
my older pc has been running 24/7 for almost 3 years with no downtime, so there is not danger to shutting it down at night or not.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Some people leave it on, others shut it down. I like to shut it down to conserve power and such. But some things like servers stay on for years, and computers as well. Either way is fine but shutting it down is just less power consumption and less constant CPU load. But leaving it on is fine.
Dual Boot Windows & Hackintosh
CPU: Intel 4790K | Motherboard: ASUS Maximus Hero Vii | GPU: Zotac AMP! Extreme GTX 970 | Display: ASUS PB278Q | Case: Phantom 630 | PSU: Corsair HX1000i
Canada eh?
Rebooting it doesn't cause it any harm, and imo its better to reboot it at least once a week to take care of any errors that may have occurred in windows and that sort of stuff.
Though I just put my computer to sleep every night then wake it up when I wake up, that way everything is good to go right away instead of having to log into windows and start all my programs and reopen all my tabs every day...
 That is an age old disscusion/argument .
Two basic camps
1) Heat cycling is bad for your components and the major heat change is at switch on and switch off so don't do it
2) Leaving computer on whilst it is not being used uses up electricity you don't need to use .
So it's a case of you pays your money and takes your choice.
The middle ground seems to be don't switch it off if you are away for half an hour or so just (say) overnight. That way you are not power cycling so much and you are not wasting power overnight.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
That's more superstition then anything else.
I would expect it to "wear" way more when running it 24/7 opposite then to turn it of at last 8 hours every night. (Your mother does sleep, doesn't she?)
Also in the lower end spectrum (where I consider AIOs to be) there is way lass voltage and heat fluctuations that really can wear down components.
And you have a big random factor of production quality.
To simplify:
Run it when you use it!
Make backups of data that you want to keep.
The machine can break 10min after you used it for the first time or it can still run fine in 20 years.
That is not true for a long time now.
CPU and GPU use significant amounts of power only on demand. And everything else does not use enough power to have big enough heat fluctuations.
Thank you all!!!
My Build, "Helios"
GPU: MSI 2080ti
I did not say this was my view just that in any disscusion on leave on/switch off these seem to be the two main 'sides'.
