Whilst this machine will be able to run wither 3 at a decent level, It will certainly not be optimal for other multi threaded tasks, because it only has 2 cores. And if you live in a country with warm summers (above 20 degrees) you would also need a better cpu cooler than Intel's stock cooler. Lastly i would also note that if you are ever going to upgrade your system, you would need to pay attention to the power usage, since 350 watts ain't a lot.
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098126
Stock cooling is more than enough
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098135
I would go for a build like this:
PCPartPicker part list: http://pcpartpicker.com/p/dWfGYJ
Price breakdown by merchant: http://pcpartpicker.com/p/dWfGYJ/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.98 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.98 @ OutletPC)
Motherboard: ECS Z97-PK (V1.0) Micro ATX LGA1150 Motherboard  ($66.98 @ Newegg)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory  ($44.99 @ Newegg)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($42.50 @ Amazon)
Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($189.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($47.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ NCIX US)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit)  ($86.75 @ OutletPC)
Total: $602.15
Generated by PCPartPicker 2015-05-31 03:54 EDT-0400
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098138
Seconded.
Total: $602.15
Thats a really nice build, with a focus on GPU over CPU (es for budget gaming)
Throw an i3/i5+SSD when you can afford it (your next upgrade maybe) and then your ACE.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098143
350watt powersupply will not be enough. Will not run WItcher 3. It requires a quad core i5 on Intel side for minimum and a 660 which I guess is somewhat similar to a 750ti. You would need to up your budget for what you want or the game will either not run or you will have to scrape the barrel for a decent framerate
System requirements:
  • MINIMUM:
    • OS: 64-bit Windows 7 or 64-bit Windows 8 (8.1)
    • Processor: Intel CPU Core i5-2500K 3.3GHz / AMD CPU Phenom II X4 940
    • Memory: 6 GB RAM
    • Graphics: Nvidia GPU GeForce GTX 660 / AMD GPU Radeon HD 7870
    • Hard Drive: 35 GB available space
  • RECOMMENDED:
    • Processor: Intel CPU Core i7 3770 3.4 GHz / AMD CPU AMD FX-8350 4 GHz
    • Memory: 8 GB RAM
    • Graphics: Nvidia GPU GeForce GTX 770 / AMD GPU Radeon R9 290
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098148
An i3 runs the witcher 3 amazingly and it is hyperthreaded. Also stock cooling is more than enough for the core i3.
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098150
Total: $602.15
The thing is i do not own a credit card so i cant use amazon ;(
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098153
  • MINIMUM:
    • Memory: 6 GB RAM
  • RECOMMENDED:
    • Memory: 8 GB RAM
Dude the minimum specs are crap. How is a phenom even in the same league as an i5. Also :
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098158
  • MINIMUM:
    • Memory: 6 GB RAM
  • RECOMMENDED:
    • Memory: 8 GB RAM
The has been a grapihcs update ;) i3 is enough
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098161
Get this build and get a windows key for cheap on reddit :
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($34.99 @ Micro Center)
Total: $586.64
Generated by PCPartPicker 2015-05-31 04:01 EDT-0400
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098175
Total: $586.64
Yep, thats the best so far, and possible the best your gunna get.  Without serious sacrifices.
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098190
Total: $586.64
No OS???
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098218
I believe they just extract the keys from old pcs or htpcs using the magical jelly bean key finder. (that name tho haha)
http://de.pcpartpicker.com/p/xJghLk
That is my final build could you just say if it will run witcher 3? and is it easy to build?
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098352
Total: $602.15
Sorry i need an i3 cause it will render faster and i dont like amd so i stick to Intel.
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098361
Get an i3 4130 and an h81 board motherboard instead and with the money saved get a better graphics card.
https://linustechtips.com/topic/377124-600-witcher-3-able-build/#findComment-5098404
