gpu for slin case with 240w power supply
err95
i just bought a cheap old hp dc7900. i bought it because i liked that it runs a dual core processor i have experience with and i figured i could slap a graphics car in it and use it as a simply little stream/ home theater machine. nothing too extreme.
after some research i have been leaning towards this gpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500276
however i have heard some hps are not capable of using their 16x slot in this way and i would need to use the 1x slot on the motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500299&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146836&SID=iabx9cr4q8000a1700053
does anyone know what the case is with this particular hp
this is what I use in my HTPC and it's pretty great, tops out at 80C, which is safe, in a almost fanless case. it's passive which makes the system dead silent
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487062&cm_re=gt_720-_-14-487-062-_-Product
