write speed drop off significantly
so i copied a large file from my SSD Samsung evo 480 250gb, latest firmware to a hdd WD 1tb and the write speed drop from 700 MB/s to around 35 MB/s writing to the SSD from the same drive hovers around 150 MB/s. both drives are hooked to the motherboards SATA III ports. wasn't sure its its just because
its a hdd or there is something wrong.
Motherboard: Asus X99 Ultimate
UEFI: 1702
PSU 850 watt rosewill photon
Graphics card: PNY GForce GT 610 Rev. A1
CPU: Intel 5820K Hex-core over clocked to 3.7Ghz
RAM: Corsair Quad-channel 16gb kit @ 3000 Mhz
SSD set to max performance with RAPID enabled
All sata set to AHCI
i realize theses are synthetic but attached is the benchmark from Samsung Magician.
Thanks
Most likely the HDD slowing things up. BTW, if you do have an 840 EVO drive, make sure to update the firmware and use Samsung's tool thing they have going on. The 840 EVOs had a few issues with old data having slower and slower read times.
EDIT: Didn't see the "latest firmware". You're staying on top of your stuff! ![]()
EDIT v2: 150 MB/s read from a HDD is normal (a tad high even), and 35 MB/s write isn't crazy slow for a HDD.
