So I just need help finding a longer power cable to turn off and on my computer. I'm making a custom on/off switch to put on my desk but the one that came with my computer doesn't reach to the top of my desk. I've been looking for a while now and still can't find anything longer than 20 inches. If you guys find anything just link it, Thanks.
This is what i'm looking for but longer.
http://www.amazon.com/Version-Coin-Replacement-Computer-Motherboard/dp/B00J8QIUJK/ref=sr_1_3?s=electronics&ie=UTF8&qid=1433021766&sr=1-3&keywords=pc+power+button
https://linustechtips.com/topic/376864-power-button-cable/
You can always get extensions for the I/O cable:
http://www.frozencpu.com/products/14126/cab-612/Bitfenix_Alchemy_Multisleeve_IO_Extension_Cable_PWRRSTHDDEtc_-_30cm_-_Black_BFA-MSC-2IO30KK-RP.html?tl=g2c537s1544
Note: FCPU link is only for reference and is still closed/out of service.
https://linustechtips.com/topic/376864-power-button-cable/#findComment-5095099
Could I get them anywhere else there out of stock there??
https://linustechtips.com/topic/376864-power-button-cable/#findComment-5095109
lol just read the note
https://linustechtips.com/topic/376864-power-button-cable/#findComment-5095114
I could do that but buying the extensions makes it easier.
https://linustechtips.com/topic/376864-power-button-cable/#findComment-5095206
