Water Cooling
Solved by W-L,
Ok so i dont know where to mount things and what should my loop be.
Here Linus had an extremes watercooling build log it should cover if not everything close to it.
For your fittings you need to make sure they are G1/4 thread and they are the correct ID and OD for the tubing.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
