What wattage PSU do I need to be able to upgrade to a GeForce GTX 970 on this build?
Solved by ZetZet,
This would be enough for you http://pcpartpicker.com/part/evga-power-supply-100b10500kr
and cheap.
And yes it would fit that computer looks remarkably standard inside, are you sure gtx 970 will fit inside or did you measure it already?
Featured Topics
Wubb ·
erico2304 ·
Posted in Troubleshooting0 -
aisle9 ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
6
