im gonna build my first ever gaming rig in a couple of months, and i need help with purchasing a graphics card
i want a card that can go 1080p 60fps with any game i throw at it and be reliable with no artifacts or none related to that
any suggestions ?? :) thanks
If you are building it in a couple of months, then the 300 series and the 900TI series will be out, so I think you should get one of those. Also, what is your budget?
RIG: CPU: i5 6600k @4.8GHz 1.34v  CPU Cooler: H100i  Motherboard: Asus Z170-AR  RAM: Corsair Vengence LPX 2400 (2x8GB)
HDD: Seagate Baracuda 2TB  SSD: Samsung 850 Evo 500GB/PNY 240GB  GPU: Gigabyte G1 Gaming GTX 970  PSU: EVGA G2 650W
Please use PcPartPicker, and paste the "BB" code when posting your build!
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085188
budget??
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085190
titan x might definitly help;-)
I'd suggest getting a 970 - only in a few games you might be not able to reach really 60fps, but they are a small amount. If you can afford it, get a 980, but i don't think this card is worth the premium price tag
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085201
this would be also a possibility, but we all cannot make any recommendations on this cards.
I wrote my previous post to pick the best card for this build on the actual available cards
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085225
my budget is $750 for the whole system itself
Hard to say what the prices for the new cards will be, maybe a 370x? Although, you could always just get a 280x, and be fine at 1080p gaming.
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085235
don't think you'll get even a 970...
then best option 280x/270x or 960...
or wait for 300 series or 960 ti sort of (don't know whether nvidia plans a nvidia 960 ti)
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085242
i was wondering if the msi radeon r9 280x would do the job
For 1080p gaming, you should be able to get high/max setting and still manage 60FPS on most games. I 1080p game on my GTX 960, and I keep settings at about high/medium/max depending on the game to get 60FPS. However the 280x is slightly more powerful then the GTX 960, and has 1 more GB of VRAM, so you should be good.
https://linustechtips.com/topic/376031-graphics-card-help/#findComment-5085360
