CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($189.98 @ Newegg)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($66.98 @ Newegg)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory  ($44.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card  ($309.30 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($55.98 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Other: /r/MicrosoftSoftwareSwap Windows 8.1 License ($20.00)
Total: $775.21
Generated by PCPartPicker 2015-05-29 00:10 EDT-0400
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082316
Snip
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082319
Total: $775.21
dis :)
although for some reason im pretty sure a 2x4 kit is better than 1x8
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082326
dis :)
This was the cheapest they had, and if OP ever needs 16 GB he can upgrade easier.
sex hahaha
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082332
dis :)
You won't notice a difference visually. Unless you do benchmarks ect.. Plus it's easier to add another 1x8 kit later.
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082333
I only have $750 I can't afford more at the moment.
You can easily save up $250 in a month and a half. For $1000 you are getting better quality, a little better performance ect.. Ect..
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082348
I need help on a PC build I only got $750 to spend, whoever gets a build a better PC on PCPartPicker will get best answer. Only newegg as merchant.
Here is the best build for just gamimg in your price range:
http://pcpartpicker.com/p/mvm2GX
However go for a 4690k and z97 mobo with sli such as the MSI sli krait for a better build with slightly higher price.
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082360
If he can only spend $750, he can only spend 750. I don't see what's so hard about that to understand...people sometimes fail to realize that people have budgets and that not everyone can has a steady source of income.
My "steady source" of income is $20 allowance every two weeks.
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5082467
http://pcpartpicker.com/p/hzJBt6
This would be a good option, and then you could just add a hyper 212 evo and a 120gb ssd when you get the funds. Over wise this will be great for 1080p, you could probably get 60+fps on Max settings.
Also over clocking the CPU would be a good idea
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5083707
The CX series are not good PSUs for the price - don't get those. XFX TS is slightly more expensive but much better quality.
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/375788-need-help-on-a-gaming-pc/#findComment-5084036
