I'm considering taking my rig to the dark side and getting wet, with the main motivator being the 290X and those toasty VRMs. My issue is that poking about I came up with ~$500 being roughly the cost before fittings and fans. Yikes!  I suspect that I might not actually have any idea what I'm doing here.
This whole bit is going to live in a Fractal Design Define S case with an HX750 PSU and all the drives behind the board. I'm not pushing for world record OC levels or anything silly like that, so $500 seems rather extreme. So that's where I query you folks:
I'd like a nice 420mm rad and a full coverage VGA block with backplate. The rest I frankly have no idea. My 290X is reference board design FWIW.
1. Overclock until the magic smoke comes out. 2. Modify until broken. 3. Fix and repeat.
4670k - 16GB - 290X - 1440p Freesync
https://linustechtips.com/topic/375670-custom-loop-for-4670k-290x/
@Circs
Have you considered going for a dual AIO setup?  It will cost you a fraction of the price, while delivering 80% of the performance.
Check out my Dual AIO Watercooling Guide
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
your about right for the price for decent parts is a 400-800$ bill good luck to you. i will never go back to air since ive gone custom loop the temps are just so much better
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
@Circs
I'm open to options and actually I was eyeballing the Swiftech H240X. On their forums they're commonly running an extra rad and a full GPU block with no further additions to the kit, which is impressive. Such a setup is even considered fine by their support people, so there's that!
The dual AIO route is one I've been thinking about too and I'll give your post a read. I *might* just have my GPU take the dip on its own since my CPU doesn't make cooling demands like a bank robber taking hostages.
Just doing your GPU with a G10 or HG10 won't be expensive at all.  $100 total probably.
