I recently upgraded my 64-bit win7 machine to win8 (via download upgrade) and got a new UPS (CyberPower CP1500AVRLCD Intelligent LCD UPS 1500VA 900W AVR Mini-Tower).  Other than that, not much has changed in my system for some time.  As of late, my computer will periodically stutter, both under load and not, and the audio will buzz/stutter as well.  If no audio is playing the speakers will just buzz a little and the cursor will skip.  RealTemp shows no CPU heating problem under load with Prime95, CPU usage does not spike either with the issue is occuring.  Could it be the new UPS or a bad power supply?
Intel i5-3570k @ 3.4GHz
(G.SKILL Ripjaws Series 4GB (2 x 2GB) F3-12800CL9D-4GBRL)  X2
ZALMAN CNPS9500
OCZ Agility 3 AGT3-25SAT3-120G
MSI N660TI PE 2GD5/OC
ASUS P8Z77-V LK
some corsair 650W PSU
https://linustechtips.com/topic/37529-stutteringbuzzing-issues/
Since that's the only change that was made, remove the UPS from the equation, and use the system again.
https://linustechtips.com/topic/37529-stutteringbuzzing-issues/#findComment-482339
Download MOBO drivers?
 CPU: Intel i5-6500 @ 3.6ghz | Mobo: Gigabyte GA-B150M D3H | RAM: Avexir Core Series 8GB (2x4GB) | Gfx: Zotac GTX970 Amp! Omega | Chasis: Phanteks Evolv ATX  | PSU: Seasonic M12II Evo 620W | SSD: Samsung Evo 850 250GB | HDD: WD 320GB |
CPU Cooler: ID-Cooling Frostflow 240l |
FANS: Corsair SP120 rear exhaust | Keyboard: Ducky Shine DK9008S | Mouse: Corsair Vengeance M60 | OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/37529-stutteringbuzzing-issues/#findComment-487020
